Discover all the fun and excitement of Google TV in excellent Sony picture and sound quality on this 4K HDR TV. The flush surface design keeps you focused on the action.
1. Buy a qualifying TV from BT Shop. The TV MUST be purchased before you order BT Broadband.
2. You will receive an exclusive code in your order confirmation email from BT Shop with a link to order your Broadband package
3. Place your Broadband package order on BT.com via your unique link
4. Receive £100 cashback!
Click here for full Terms and Conditions.
Product Description | Sony KD-55X85K X85K Series - 55" Class (54.6" viewable) LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 55" | Diagonal Size | 54.6" | Colour | Black | Platform | Google TV | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | Input Video Formats | 480p, 1080/24p, 1080/60i, 720/60p, 1080/60p, 1080/30p, 720/24p, 720/30p, 3840/24p, 3840/30p, 3840/60p, 4096/24p, 4096/60p, 1080/120p, 3840/120p | HDR Format | HDR10, Dolby Vision | HDR Technology | Dolby Vision, HDR 10, Hybrid Log-Gamma (HLG), Object-based HDR remaster | Frame Rate & Enhancement Technology | Motionflow XR 960, 120 Hz Native Refresh Rate, Variable Refresh Rate (VRR) | Video Interface | Composite, HDMI | HDMI Ports Qty | 4 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | Direct LED frame dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | ATSC 3.0 (NextGen TV), ClearQAM | Internet Streaming Services | Google TV, Voice Search, Chromecast | Picture Enhancements | Live Color, 4K X-Reality PRO Engine, Auto Calibration, Dynamic Contrast Enhancer, dynamic backlight control | Speaker System | 2 speakers, 2 tweeters | Sound Effects | DTS Digital Surround | Platform | Apple HomeKit | Storage Capacity | 16 GB | USB | 2 ports | Included Accessories | Remote control | Voltage | AC 110-240 V (50/60 Hz) | Energy Class | Class G | Power Consumption Stand by | 0.5 Watt | Dimensions (WxDxH) - without stand | 123.3 cm x 7.2 cm x 71.1 cm | Weight | 17.1 kg |
General | |
Energy Class (HDR) | Class G |
Power Consumption SDR (On mode) | 92 kWh/1000h |
Power Consumption HDR (On mode) | 128 kWh/1000h |
Series | X85K Series |
Model Year | 2022 |
Video Processor | 4K HDR X1 |
TV Tuner Presence | Yes |
Sensors | Light sensor |
Modes | Backlight off mode, Auto Low Latency Mode (ALLM) |
Design | Flush Surface design |
Dimensions | Without stand |
Width | 123.3 cm |
Depth | 7.2 cm |
Height | 71.1 cm |
Weight | 17.1 kg |
Enclosure Colour | Black |
Display | |
LCD Backlight Technology | Direct LED - frame dimming |
Display Menu Language | Multilingual |
Features | Audio Description (AD), Dynamic Backlight Control, Apple AirPlay support, screen reader, text magnification, Auto Genre Selection, Triluminos Pro Display |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Stand Colour | Black |
Stand Features | Slim Blade Stand |
Flat Panel Mount Interface | 300 x 300 mm |
VESA Compatibility | Yes |
TV Tuner | |
Channel Coverage | VHF:2-13, UHF:14-69, Cable:1-135 |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Electronic Programme Guide | Digital EPG |
Closed Caption Capability | Yes |
Media Player | |
Supported Video Formats | MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, ASF, AVI, MKV, MOV, AVCHD, TS, AVC, 3GPP, PS, VC-1, WebM, HEVC, VP8, XAVCS, HDV |
Supported Audio Formats | MP3, WMA, WAV, AAC, FLAC (Free Lossless Audio Codec), LPCM, ASF |
Supported Pictures Formats | JPEG |
USB Port | Yes |
USB Ports Qty | 2 |
Configuration | 16 GB |
Operating System | Android TV |
Remote Control | |
Type | Remote control |
Battery Included | Yes |
Features | Voice control |
Audio System | |
Digital Audio Format | Dolby Atmos, Dolby Audio |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Audio Return Channel (ARC), Sound Optimizer, Bass Reflex Speaker System, Enhanced Audio Return Channel (eARC), X-Balanced Speaker, Acoustic Auto Calibration, Room Compensation |
Speakers | 2 x speaker , 2 x tweeter |
Driver Details | Speaker: 1 x full-range driver |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac |
Bluetooth Version | Bluetooth 4.2 |
Connect & Share | Wi-Fi Direct, Bluetooth Human Interface Device (HID) |
Supported Consumer Electronics Control (CEC) | BRAVIA Sync Function |
Application Store | Google Play |
Connections | |
Connector Type | Network - side , Composite video input - side , 4 x HDMI - side , RS-232C input - side , Digital audio output - side , 2 x USB - side |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Compliant Standards | HDCP 2.3 |
Power | |
Power Device | Power supply |
Input Voltage | AC 110-240 V (50/60 Hz) |
Auto On/Off | Yes |
Features | On/off timer, energy saving mode |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 123.3 cm x 7.2 cm x 71.1 cm x 17.1 kg , Panel with stand - 123.3 cm x 33.8 cm x 78.2 cm x 18.1 kg , Stand - 106.1 cm |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 136.2 cm |
Depth (Shipping) | 16 cm |
Height (Shipping) | 84.7 cm |
Weight (Shipping) | 24 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
