Sony a NEX 3NL - Digital camera - mirrorless system - 16.1 Mp...
FREE DELIVERY
Sony a NEX 3NL - Digital camera - mirrorless system - 16.1 Mpix - 16-50mm lens - black
Key features
  • Capture every tiny detail
  • Shoot self-portraits and tricky angles
  • Go anywhere and never miss an opportunity
  • Compose shots like a professional
  • Be ready for anything with a power zoom lens
  • Get the detail when the lights are low
Product codes
Take the creativity of a DSLR anywhere with the easy-to-use NEX-3N. With a large 16.1-megapixel APS-C sensor, you can shoot detailed images in low light, use the handy 180° tiltable screen for self-portraits or tricky angles, and give your photography that professional look.
When it comes to camera sensors, bigger really is better. The NEX-3N has a large, DSLR-quality APS-C sensor which captures more light than most other interchangeable lens cameras, so more detail reaches the sensor. The result is beautifully lit shots up to 16.1-megapixel.
The NEX-3N body is slim and light, and ready to go where you go, but it also has the capabilities of DSLR cameras twice its size. What's more, the kit comes with a compact, lightweight power zoom lens so you can be creative anywhere, any time.
Product Description Sony a NEX 3NL - digital camera 16-50mm lens
Product Type Digital camera - mirrorless system
Lens Included 16-50mm lens
Memory Card Slot Memory Stick PRO Duo card, SD card
Image Processor BIONZ
Sensor Resolution 16.1 Megapixel
Max Video Resolution 1920 x 1080
Lens System Zoom lens - 3x zoom - 16 - 50 mm - f/3.5-5.6 PZ OSS
Focus Adjustment Automatic, manual
Min Focus Distance 25 cm
Digital Zoom 4x
Image Stabiliser Optical (Steady Shot)
Camera Flash Pop-up flash
Display LCD display - 3"
Supported Battery 1 x Sony NP-FW50 Li-ion rechargeable battery (included)
Interface HDMI
Microsoft Certification Compatible with Windows 7
Colour Black
Dimensions (WxDxH) 10.99 cm x 3.46 cm x 6.2 cm
Weight 210 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
