Sony DSC-W800 Compact Digital Camera Silver 20.1 MP 5 x Optic...
Sony DSC-W800 Compact Digital Camera Silver 20.1 MP 5 x Optical Zoom
Key features
  • 20.1 MP super HAD CCD sensor
  • 5x optical zoom with SteadyShot image stabilization
  • 720p HD movie video mode
  • Easy mode simple camera menus
  • 360° sweep panorama mode
  • Smile shutter, picture effects
  • USB battery charge
Product codes
This incredibly easy-to-use camera slips right in your pocket, ready to capture a memory at a moment's notice. Get close to faraway subjects with 5x optical zoom, then snap gorgeous 20.1 MP photos or record beautifully detailed HD video. Your pictures will come out crisp and clear thanks to the professional-grade Sony lens with Optical SteadyShot image stabilization. For even more fun, enhance your stills and video with built-in creative effects like toy camera and pop color. Or try beauty effects to adjust skin tones, remove blemishes and even whiten teeth-it's perfect for portraits.
Don't let a not-so-steady hand prevent you from capturing the moment. Optical SteadyShot image stabilization with intelligent active mode compensates for camera shake by countering camera movements in both horizontal and vertical directions. Get sharp, blur-free footage and photos in otherwise unsteady situations, like shooting video while walking or zoomed in.
Product Description Sony Cyber-shot DSC-W800 - digital camera
Product Type Digital camera - 720p - compact
Memory Card Slot Memory Stick PRO Duo card, SD card
Image Processor BIONZ
Sensor Resolution 20.1 Megapixel
Max Video Resolution 1280 x 720
Lens System Zoom lens - 5x zoom - 4.6 - 23 mm - f/3.2-6.4
Focus Adjustment Automatic, manual
Min Focus Distance 5 cm
Digital Zoom 10x
Image Stabiliser Optical (Steady Shot with Intelligent Active Mode)
Camera Flash Built-in flash
Display LCD display - 2.7"
Supported Battery 1 x Sony NP-BN Li-ion rechargeable battery - 630 mAh (included)
Interface Composite video/audio, USB 2.0
Colour Silver
Dimensions (WxDxH) 9.68 cm x 2.08 cm x 5.55 cm
Weight 109 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony DSC-W800 Compact...
