Sony ILCE-5000 Alpha A5000 SLR Camera Black 16-50mm Lens 20
Key features
  • 20.1 MP Exmor HD APS sensor
  • BIONZ X image processing engine
  • Low light situations not a problem
  • Face detection/Smile shutter
  • Full HD 1080/60i/24p or 1080/30p MP4 movies
  • Convenient Power zoom lens with motor zoom lever and KeySellingPoints control
  • Auto Object Framing fills the frame with your subject
  • Up to 420 Shots of battery life
  • Beautifully composed self-portraits made easy
Product codes
The world's smallest and lightest interchangeable lens camera, the ILCE-5000 features a 20.1 effective megapixel Exmor APS HD CMOS sensor and powerful BIONZ X image processor for pro performance. A 180° tiltable LCD screen lets you experiment with new angles and shots.
Product Description Sony a5000 ILCE-5000L - digital camera 16-50mm lens
Product Type Digital camera - mirrorless system
Lens Included 16-50mm lens
Memory Card Slot Memory Stick PRO Duo card, SD card
Image Processor BIONZ X
Wireless Interface Wi-Fi, NFC
Sensor Resolution 20.1 Megapixel
Max Video Resolution 1920 x 1080
Lens System Zoom lens - 3x zoom - 16 - 50 mm - f/3.5-5.6 PZ OSS
Focus Adjustment Automatic, manual
Min Focus Distance 25 cm
Digital Zoom 4x
Image Stabiliser Optical (Steady Shot)
Camera Flash Pop-up flash
Display LCD display - 3"
Supported Battery 1 x Sony NP-FW50 Li-ion rechargeable battery - 1080 mAh (included)
Interface HDMI
Microsoft Certification Compatible with Windows 7
Colour Black
Dimensions (WxDxH) 10.96 cm x 3.57 cm x 6.28 cm
Weight 210 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony ILCE-5000 Alpha A...
