Sony MDR V150 - Headphones ( ear-cup ) - black
£18.74
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Wide, molded headband enhances stability & comfort
  • 30 mm driver unit for high quality sound
  • Closed, supra-aural design
  • Oxygen-free copper connecting cord
  • Stereo UniMatch plug
  • Accessory Type: Headphones
  • Connectivity: Wired
  • Colour: Black
  • Stock Status: In Stock
Product codes
Studio Monitor Series Headphones incorporate high-end materials and advanced engineering; critically clean, exceptionally clear sound for professional and high fidelity applications. Reversible earcups enable single-sided monitoring flexibility. 30 mm diameter drive units are larger than many headphones for deeper bass, lower distortion and wider dynamic range; bass response extends down to a low 18 Hz. 500 mW power handling stands up to day-in, day-out use at high output levels. Ferrite magnets allow for high energy and compact size producing ample sound output - 98 dB/mW sensitivity. Oxygen-free copper cord assures maximum conductivity, minimum noise. It conducts electricity better than conventional copper. Supra-aural design rests lightly on the ear and creates a controlled environment for better sound. Driver is positioned the correct distance from the ear canal. Wide, molded headband distributes the headphone's weight over a wide area; reduced pressure means comfortable listening for hours on end.
Product Description Sony MDR-V150 - headphones
Product Type Headphones - wired - 3.5 mm jack
Recommended Use Professional audio, home audio, portable electronics
Colour Black
Headphones Form Factor Full size
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Audio Specifications Frequency Response 18 - 22000 Hz - Sensitivity 98 dB
Impedance 24 Ohm
Diaphragm Type PET
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony MDR V150 - Headph...
£18.74
