Sony MEMORY STICK PRO DUO 4 GB
Key features
  • Designed for a variety of applications, including high capacity digital photography, video, music and data
  • Minimum write speed of 32Mbps on Memory Stick PRO Duo optimized devices
  • MagicGate compatible
  • Compatible with PS3 and PSP
Product codes
Memory Stick PRO Duo Mark2, 4GB, is the ideal choice for HD recording with 1920 x 1080 AVCHD recording capability and a minimum write speed of 32Mbps. 1/3 the size of Memory Stick PRO is designed for use in ultra compact devices.
Product Description Sony - flash memory card - 4 GB - Memory Stick PRO Duo Mark2
Product Type Flash memory card
Form Factor Memory Stick PRO Duo Mark2
Storage Capacity 4 GB
Supply Voltage 2.7 - 3.6 V
Designed For Cyber-shot DSC-TX100, DSC-TX100V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony MEMORY STICK PRO...
