Sony PS5 DualSense Edge Wireless Controller
FREE DELIVERY
£209.00
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Perfect Your Gameplay
  • Ultra-customizable controls
  • Quick access profile settings menu
  • Remappable buttons
  • Adjustable triggers, stick sensitivity and vibration intensity
  • Quick-swap control profiles
  • Compatibility: Sony PlayStation 5
Product codes
Bundle deals (1)
STICK MODULE FOR EDGE WIRELESS CONTROLLER
= £209.00
Save £19.99
Built with high performance and personalization in mind, this controller invites you to craft your own unique gaming experience so you can play your way.
Perfect Your Gameplay™
Find your edge with customizable controls and swappable profiles that can help equip you for anything from pro level tournaments to epic single player adventures.
Custom settings make your DualSense Edge wireless controller uniquely yours.
Changeable stick caps - Three types of changeable stick caps help you stay comfortable in-game without sacrificing grip or stability.
On-controller user interface - Quickly swap between your pre-set control profiles and adjust game volume and chat balance from the controller’s dedicated function button. (Analogue audio connection to headset required for full compatibility. Audio balance adjustable when in party chat.)
Replaceable stick modules - Play for longer with swappable replacement stick modules available to purchase separately.
Mappable back buttons - Two swappable sets of back buttons, configurable to many other button inputs, put essential controls at your fingertips.
Adjustable trigger lengths - Manually set the travel distance of your left and right triggers for an optimal experience with whatever you’re playing.
USB braided cable with lockable connector housing - Lock the included 9.1ft/2.8m USB cable in place so it's much less likely to slip out at a crucial moment.
DualSense™ wireless controller features built in
Experience all the immersive features of the DualSense wireless controller, including haptic feedback, adaptive triggers, a built-in microphone, motion controls and more in supported titles.
Signature comfort and slip-resistant inner grips
Enjoy the same signature comfort of the original DualSense wireless controller, now enhanced with slip-resistant inner grips. Ideal for long sessions in single player games and staying comfortable during intense competitive play.
Compatible with the DualSense charging station
Keep two controllers fully charged - including your DualSense Edge wireless controller - with the quick and easy click-in design of the DualSense charging station, available to buy now. (Sold separately).
Promotions (1)
TRADE IN YOUR OLD CONSOLE
Got an old games console lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description Sony DualSense Edge - gamepad - wireless - Bluetooth
Product Type Gamepad
Connectivity Technology Wireless - Bluetooth
Controls PS button, directional buttons, action buttons, dual point touch pad, Options button, L1 Button, R1 Button, R2 Button, L2 Trigger, Create button, Left stick / L3 Button, Right stick / R3 Button, Touch Pad button, Mute button
Features Built-in speaker, headset port, profile switch, vibration, built-in microphone, adjustable vibration, capacitive touch pad, Click Mechanism, SIXAXIS motion technology, Light Bar, three-axis gyroscope, three-axis accelerometer, built-in USB-C charging port, Trigger Effect, adjustable triggers, buttons remap, adjustable stick sensitivity
Manufacturer Warranty 1-year warranty
Designed For Sony PlayStation 5
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£209.00
