Sony S Series VPL-SW536C WXGA 3000 Lumens Projector
Key features
  • WXGA widescreen resolution
  • Eco mode key
  • ECO lamp dimming
  • ECO picture mute
  • Digital/HD ready
  • Automatic keystone adjustment
  • Smart APA (Auto Pixel Alignment)
  • Auto input search
  • Picture muting/audio muting
  • Audio switcher facility
  • Picture freeze function
  • Digital zoom
  • Off and go
  • Direct power on/off
  • Filter cleaning at the same time as lamp replacement
Product codes
Designed for education, the VPL-SW536 WXGA projector provides the perfect teaching tool for glare-less projection in changing light conditions. The VPL-SW536 WXGA projector with easy installation and multiple media connectivity is an ideal choice for ultra-close projection applications in educational markets. Excellent contrast, consistent color stability, high picture quality and longer durability improve visibility enhancing teaching quality.
Product Description Sony VPL-SW536C - 3LCD projector - LAN
Device Type 3LCD projector - 720p
Colour White
Built-in Devices Speaker
Bundled Services 3 years PrimeSupport
Brightness 3100 lumens
Contrast Ratio 2500:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Lens Shift Direction Horizontal, vertical
Bulb type Ultra high-pressure mercury 210 Watt
Bulb life cycle Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
Video Modes 480/60p, 720/60p, 720/50p, 576/50p, 480/60i, 576/50i
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 282 Watt
Dimensions (WxDxH) 38.44 cm x 42.34 cm x 12.25 cm
Weight 6.9 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony S Series VPL-SW53...
