Sony SAL1650 16-50mm f/2.8 Zoom Lens A Mount for Alpha
£648.96
Delivery:
Key features
  • Versatile and easy to carry with premium optics
  • Smooth, quiet autofocus with stills or HD movies
  • Ideal for wide range of everyday applications
  • Superb resolution and contrast
  • Weather- and dust-resistant design
Product codes
SAL1650 is a high quality standard telephoto lens, ideal for wide range of everyday applications, including portraits, travel, landscapes and general-purpose shooting. Bright F2.8 maximum aperture allows creation of smooth background defocus effects (bokeh). High performance optics achieve versatile zoom range in light, easy-to-carry lens body. Internal SSM (Super Sonic wave Motor) drive achieves exceptionally fast, quiet autofocus - ideal for stills and HD movie shooting. Aspherical lens elements and ED glass elements suppress aspheric and chromatic aberration for superb resolution and contrast. Rugged weather-resistant design with interlocking seals protects against effects of dust and moisture.
Sony SAL1650 - zoom lens - 16 mm - 50 mm
Lens System
Zoom lens
Intended For
Digital SLR
Mounting Type
Sony A-type
Lens Aperture
F/2.8
Focal Length
16 mm - 50 mm
Optical Zoom
3 x
Min Focus Distance
30 cm
Focus Adjustment
Automatic, manual
Lens Construction
13 groups / 16 elements
Special Functions
Zoom
Filter Size
72 mm
Length
8.8 cm
0.58 kg
? SLT-A57, SLT-A57K, SLT-A57M, SLT-A57Y, SLT-A58K, SLT-A58M, SLT-A58Y, SLT-A65, SLT-A65VK, SLT-A65VL, SLT-A65VM, SLT-A65VY; a58 SLT-A58
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony SAL1650 16-50mm f...
£648.96
