Sony VPL-CH375 WUXGA 3LCD 5000 Lumens Projector
£1,400.00
Delivery:
Standard: 1-3 working days
Key features
  • High resolution WUXGA image
  • High image quality 3LCD BrightEra natural and vivid color images with high brightness
  • Fine lens shift
  • Connectivity via HDBaseT
  • Blend-in design
  • Advanced energy-saving features
  • Brightness: 5000ANSI lumens
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
The VPL-CH375 delivers an outstanding brightness of 5000 lumens and ultra high-quality images with WUXGA resolution. Sony 3LCD BrightEra panel technology provides higher picture quality, substantially brighter images, higher efficiency, consistent color stability and longer durability. It also delivers installation flexibility, environment-friendly features, and a low total cost of ownership, in a stylish design that blends into any decor. The lens shift/zoom capability and the image correction features easily allow users to fit any image onto the screen, even from an offset projection angle.
The projector allows simple connectivity using an HDBaseT digital interface, multi signal transmission system, providing a single cable, cost-effective, long-distance, and high-quality digital transmission solution. Additionally, the projector is economically designed for optimum energy efficiency, thanks to its energy saving features and has all the features and functionality that you would expect from Sony, particularly in terms of installation, projection, usability and maintenance.
Product Description Sony VPL-CH375 - 3LCD projector
Device Type 3LCD projector - 1080p
Built-in Devices Speaker
Brightness 5000 lumens
Contrast Ratio 2500:1
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Lens Shift Direction Horizontal, vertical
Bulb type Ultra high-pressure mercury 280 Watt
Bulb life cycle Up to 2500 hour(s) - normal mode , Up to 3500 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Video Modes 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers Speaker(s) - integrated
Power AC 100/230 V (50/60 Hz)
Power Consumption Operational 367 Watt
Dimensions (WxDxH) 40.6 cm x 33.05 cm x 11.3 cm
Weight 5.7 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-CH375 WUXGA 3...
£1,400.00
