Sony VPL-EW315 1600 x 1200 RGB HDMI Projector
Key features
  • Bright, clear images
  • 3LCD BrightEra technology
  • WXGA resolution
  • Powerful audio
  • Energy efficient with long-lasting lamp life
  • Advanced energy-saving
  • Networked presentations
  • Present wirelessly
  • USB media viewer
  • Dual HDMI inputs
  • Easier maintenance
  • Quiet operation
Product codes
This projector is ideal for mid-sized or larger classrooms and meeting rooms. Quiet, compact and powerful, it delivers bright, detail-packed WXGA images with impressive output that can be seen clearly even in bright rooms, with its 3LCD technology assuring natural, vivid colors. It is an ideal partner for the integrated AV / IT environments, expanding your connectivity options with dual HDMI ports and direct USB display connection. A convenient input labeling makes life simpler, confirming on screen the name of connected devices. Add this projector to a network and see presentations from up to four connected computers simultaneously. Control the projector remotely from smartphones and tablets. You don't even need to bring a PC to meetings - just slip in a USB thumb drive and start presenting. A range of energy-saving features and long-lasting lamp life contribute to low ownership costs. Maintenance is simplified by a rear lamp access feature.
Sony VPL-EW315 - 3LCD projector - 802.11 b/g/n wireless / LAN
3LCD projector - 720p
Built-in Devices
Speaker
Brightness
3800 lumens
Brightness (Colour)
3800 lumens
Contrast Ratio
3700:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Ultra high-pressure mercury 225 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), IEEE 802.11 b/g/n wireless / LAN
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
300 Watt
36.5 cm x 25.2 cm x 96.2 cm
4.1 kg
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-EW315 1600 x...
