Sony VPL-EW348 XGA 4200lm RGB HDMI 3LCD Projector
Key features
  • Bright, clear images with maximum 4,200 lumens color light output
  • 3LCD BrightEra technology
  • WXGA resolution
  • Powerful 16W audio
  • Energy efficient with long-lasting lamp life up to 10,000 hours
  • Advanced energy-saving features
  • Quick go
  • Networked presentations
  • Control and management from any networked PC
  • USB media viewer
  • Supports HDBaseT
  • Dual HDMI inputs
  • USB Display function for easy one-cable PC connection
  • Customized input naming labels
  • Easier maintenance
  • Quiet operation
Product codes
The VPL-EW348 projector is ideal for mid-sized and larger classrooms and meeting rooms.
Quiet, compact and powerful, it delivers bright, detail-packed WXGA images with 4,200 color light output that can be seen clearly even in bright rooms, with Sony's 3LCD technology assuring natural, vivid colors.
The VPL-EW348 is an ideal partner for today's integrated AV/IT environments, expanding your connectivity options with HDBaseT, dual HDMI ports and Direct USB Display connection. A convenient input label function makes life simpler, confirming on screen the name of connected devices.
Add the VPL-EW348 to a network and see presentations from up to four connected PC/Mac computers simultaneously. Slip in an optional Wi-Fi dongle and present directly wirelessly from laptops, phones or tablets. Control the projector remotely with a free app for smartphones and tablets. You don't even need to bring a PC to meetings - just slip in a USB thumb drive and start presenting.
A range of energy-saving features and long-lasting lamp life contribute to low ownership costs. Maintenance is simplified by a new rear lamp access feature.
Product Description Sony VPL-EW348 - 3LCD projector - 802.11 b/g/n wireless / LAN
Device Type 3LCD projector - 720p
Built-in Devices Speaker
Brightness 4200 lumens
Brightness (Colour) 4200 lumens
Contrast Ratio 3700:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Bulb type Ultra high-pressure mercury 225 Watt
Bulb life cycle Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), IEEE 802.11 b/g/n wireless / LAN
Video Modes 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 329 Watt
Dimensions (WxDxH) 36.5 cm x 25.2 cm x 96.2 cm
Weight 4.1 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-EW348 XGA 420...
