Sony VPL-FH31 WUXGA LCD 4300 Lumens Projector
£2,105.32
Delivery:
Standard: 1-3 working days
Key features
  • 3 LCD XGA BrightEra panel technology
  • Ultra high resolution
  • Very high brightness: 4,300 Lumens Color Light Output
  • Wide zoom range (x1.6) and throw ratio (1.4 to 2.3) as standard
  • Wide lens shift range: vertical: +60%, horizontal: +/- 32%
  • Long lamp replacement time: 3,000-4,000 hours (High/Std)
  • Lamp/filter replacement cycles synchronized
  • Interchangeable lenses: Z1024, Z1032
  • Edge blend
  • Warping projection
  • Portrait mode
  • Side by side image projection
  • DICOM GSDF Simulation
  • Wide range of image adjustments
  • User panel alignment
  • Color matching
  • Lower operating power consumption than previous models
  • Brightness: 4300ANSI lumens
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
The VPL-FH31 is designed to fit smoothly into almost any environment where a high-quality projector is required. Its brightness, zoom and throw range, coupled with its wide lens shift range, mean it can perform where other projectors would struggle - even in high ambient light.
Once installed, the VPL-FH31 has excellent image capabilities and a long lifespan that delivers low Total Cost of Ownership. Sony's BrightEra technology improves and maintains color purity throughout the life of the system by protecting the LCD panels against harmful ultra violet light. Clever features such as synchronized lamp and filter replacement cycles reduce costs and downtime.
Featuring the usual wide range of features, the VPL-FH31 also allows for edge blend (multiple projectors with seamless connection), warping and Portrait mode installation for retail, corporate signage applications. Other features include advanced projection capabilities such as side-by-side image projection and DICOM medical training, the VPL-FH31 is an obvious projector choice for venues that demand quality, unique installation locations and practicality.
Product Description Sony VPL-FH31 - 3LCD projector
Device Type 3LCD projector
Brightness 4300 lumens
Contrast Ratio 2000:1
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Lens Shift Direction Horizontal, vertical
Bulb type UHP 275 Watt
Bulb life cycle Up to 3000 hour(s) - normal mode ¦ Up to 4000 hour(s) - economic mode
Video Input RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Digital Video Standard Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes 1080/24p, 1080/60i, 480/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 380 Watt
Dimensions (WxDxH) 39 cm x 47.7 cm x 14.8 cm
Weight 8 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-FH31 WUXGA LC...
£2,105.32
