Sony VPL-FH500L WUXGA LCD 7000 Lumens Projector
£7,400.13
Delivery:
Key features
  • 3-LCD XGA BrightEra Panel technology
  • Ultra high resolution
  • Ultra high brightness
  • Wide lens shift range
  • Interchangeable lenses
  • Dual lamp capacity, auto-switched, giving effective lamp life
Product codes
The VPL-FH500L's outstanding portfolio of features allows it to offer class-leading projection performance even in the most challenging of environments. Its 7,000-lumen color light output brightness, its zoom and its wide lens shift range, allow it to deliver the clearest image where other projectors would struggle - even in high ambient light.
Once installed, the VPL-FH500L has excellent image capabilities and a long lifespan that delivers low total cost of ownership. Sony's BrightEra technology improves and maintains color purity throughout the life of the system by protecting the LCD panels against harmful ultra violet light. Clever features such as dual auto-switching lamps, and synchronized lamp and filter replacement cycles, reduce maintenance costs and downtime.
Featuring the usual wide range of inputs, an external monitor connection for the presenter's convenience, and advanced projection capabilities such as side-by-side image projection and DICOM medical training, the VPL-FH500L is the projector of choice for venues that demand the high quality in the practical, flexible form.
Product Description Sony VPL-FH500L - 3LCD projector - no lens - LAN
Device Type 3LCD projector
Colour Grey, white
Networking Ethernet, Fast Ethernet
Brightness 7000 lumens
Brightness (Colour) 7000 lumens
Contrast Ratio 2500:1
Resolution 1900 x 1200
Lens No lens
Bulb type 2 x
Bulb life cycle Up to 6000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Digital Video Standard High-Definition Multimedia Interface (HDMI)
Video Modes 480p, 720p, 1080i, 1080p, 480i
Video Output RGB, S-Video, composite video, component video
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 53 cm x 54.5 cm x 21.3 cm
Weight 20 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-FH500L WUXGA...
£7,400.13
