Sony VPL-FW60 5200 Lumens WXGA 3LCD Technology RGB DVI HDMI
£2,153.96
Delivery:
Key features
  • Very high image quality with BrightEra 3LCD projection engine
  • Advanced picture refinement technologies
  • Crisp WXGA image quality
  • Hassle-free automatic filter cleaning
  • Energy-saving lamp dimming mode
  • Powered wide lens shift
  • Supports HDBaseT
  • Create super-size displays with edge blending
  • Project onto non-flat surfaces with image warping
  • Quiet operation
  • Slim, attractive blend-in design
  • Picture mode
  • Simple set-up with friendly installation menu
  • Project side by side
Product codes
The VPL-FW60 installation projector is ideal for a wide range of business, education and entertainment applications. The energy-efficient High Pressure Mercury (HPM) lamp source is teamed with Sony's advanced BrightEra 3LCD projection engine to deliver extremely bright, crisp WXGA resolution images with powerful 5200 lumens maximum light output and rich, stable colors. Reality creation and contrast enhancer technologies fine-tune image quality even further to assure exceptional clarity and realism with every presentation.
Offering a stylish blend-in design, tidy cable management and low fan noise, the VPL-FW60 fits smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Seamlessly blend images from multiple projectors to create super-sized displays, or project accurately proportioned images onto angled or curved surfaces. Mount the projector at any angle, even on its side or upside down. Set-up is easy with a friendly installation menu.
Sony VPL-FW60 - 3LCD projector - standard lens - LAN
3LCD projector - 720p
Brightness (White)
5200 lumens
Brightness (Colour)
5200 lumens
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
Ultra high-pressure mercury 280 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
404 Watt
46 cm x 51.5 cm x 16.9 cm
13 kg
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-FW60 5200 Lum...
£2,153.96
