Sony VPL-FWZ60 5000 ANSI Lumens WXGA 3LCD Technology DVI HDMI
£4,503.37
Delivery:
Key features
  • Very high image quality with Sony's advanced BrightEra 3LCD projection engine and Z-Phosphor laser light source
  • Constant Brightness
  • Advanced picture refinement technologies
  • Crisp WXGA image quality
  • Long hours operation with virtually no maintenance
  • Hassle-free automatic filter cleaning
  • Energy saving features
  • Save time with every presentation
  • 360° free-angle installation capability
  • Powered wide lens shift
  • Included powered standard zoom lens plus wide choice of lens options
  • Supports HDBaseT
  • Create super-size displays with Edge Blending
  • Project onto non-flat surfaces with Image Warping
  • Quiet operation
  • Attractive blend-in design
  • Picture mode
  • Simple set-up with friendly Installation menu
  • Project Side by Side
Product codes
The VPL-FWZ60 laser projector is ideal for a wide range of business, education and general presentation applications. The powerful Z-Phosphor laser light source is teamed with Sony's advanced BrightEra 3LCD projection engine to deliver extremely bright, crisp WXGA resolution images with generous 5,000 lumens maximum light output and rich, stable colours. Constant Brightness maintains the same brightness throughout the 20,000 hours recommended life span.
The laser light source allows up to 20,000 hours of virtually zero maintenance operation without the worry of sudden lamp failures. An automated filter system cuts the hassle of regular dust cleaning. Near-zero maintenance needs are complemented by a range of energy-saving feature, significantly driving down total lifetime ownership costs.
Offering a stylish blend-in design, tidy cable management and low fan noise, the VPL-FWZ60 fits smoothly into almost any environment - from academic institutions, corporate, medical training and public sector organizations to visitor attractions and retail spaces. Seamlessly blend images from multiple projectors to create super-sized displays, or project accurately proportioned images onto angled or curved surfaces. Mount the projector at any angle, even on its side or upside down. Set-up's easy with a friendly installation menu.
Sony VPL-FWZ60 - 3LCD projector - standard lens - LAN
3LCD projector - 720p
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
Laser diode
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
372 Watt
46 cm x 51.5 cm x 16.9 cm
16 kg
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-FWZ60 5000 AN...
£4,503.37
