Sony VPL-FX30 XGA LCD 4200 Lumens Projector
£1,320.00
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 3 LCD XGA BrightEra inorganic LCD panels
  • 4200 ANSI lumens high brightness
  • Standard lens has wide manual zoom (x1.6) and throw ratio (1.4 to 2.3)
  • Wide lens shift range
  • Long lamp replacement time
  • Filter maintenance synchronized with lamp replacement
  • Lower operating power consumption than previous models
  • Wide range of inputs for a variety of source devices
  • Brightness: 4200ANSI lumens
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
With an excellent 4,200 ANSI lumens output and XGA resolution, the VPL-FX30 is a versatile choice for a wide range of applications. Able to project detailed, sharp images onto screens up to 600" (diagonal) and with a comprehensive range of adjustments to help installers, this outstanding projector can slot into almost any type of venue.
By massively increasing the LCD panel's resistance to ultraviolet light, BrightEra improves reliability. At the same time, BrightEra shows its superiority over other LCD panels by allowing an increased aperture ratio, which results in a much brighter image, without the drawbacks that can affect other types of high-brightness systems.
The VPL-FX30 is a dependable tool for delivering professional presentations, every day, for years. Fully kitted-out with all the I/O you'll need - including a network connection - it's easy to connect and manage.
It features long lifespan, low cost-of-ownership, and great image quality. The VPL-FX30 is the best reason yet to upgrade to a Sony.
Product Description Sony VPL-FX30 - 3LCD projector - standard lens
Device Type 3LCD projector
Colour Grey, white
Brightness 4200 lumens
Brightness (Colour) 4200 lumens
Contrast Ratio 2000:1
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Lens Standard lens
Lens Shift Direction Horizontal, vertical
Bulb type High-pressure mercury 230 Watt
Bulb life cycle Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Output RGB
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 39 cm x 47.7 cm x 14.8 cm
Weight 7.9 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-FX30 XGA LCD...
£1,320.00
