Sony VPL-FX35 XGA LCD 5000 Lumens Projector
£1,038.67
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • BrightEra technology
  • Very high brightness
  • Wide zoom range as standard
  • Wide lens shift range
  • Interchangeable lenses
  • Long lamp replacement time
  • Lamp/filter replacement cycles synchronized
  • Lower power consumption
  • Multiple input types
  • Monitor output
  • Wide range of image adjustment
  • Brightness: 5000ANSI lumens
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Designed to fit into almost any situation that needs a high quality projector, the VPL-FX35 is perfect for installations and for updating older equipment; installers will often be able to re-use existing mounts and fittings. Versatile image adjustability and lens options allow installers to place the VPL-FX35 in locations where other projectors would struggle to work - even in high ambient light.
In addition to all this flexibility, the VPL-FX35 has excellent image capabilities and a long lifespan. Sony's BrightEra technology improves and maintains color purity throughout the life of the system by protecting the LCD panels against harmful ultra violet light.
There's no need to worry about connections, either, because the VPL-FX35 has the usual host of inputs.
Simple to use and maintain, extremely functional, and with a low cost-of-ownership, this is an obvious projector choice for venues that demand quality and practicality.
Product Description Sony VPL-FX35 - 3LCD projector - standard lens
Device Type 3LCD projector
Colour Grey, white
Networking Ethernet, Fast Ethernet
Brightness 5000 lumens
Brightness (Colour) 5000 lumens
Contrast Ratio 2000:1
Resolution XGA (1024 x 768)
Native Aspect Ratio 4:3
Lens Standard lens
Lens Shift Direction Horizontal, vertical
Bulb type High-pressure mercury 275 Watt
Bulb life cycle Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Digital Video Standard Digital Visual Interface (DVI)
Video Modes 1080/60i, 480/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i, 750/50p, 750/60p
Video Output RGB
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 39 cm x 47.7 cm x 14.8 cm
Weight 8 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Sony VPL-FX35 XGA LCD...
£1,038.67
