Sony VPL-FX500L XGA LCD 7000 Lumens Projector
Key features
  • 3 LCD XGA BrightEra panel with enhanced UV protection to reduce the effect of heating on the LCD panel
  • Standard lens has wide manual zoom
  • Dual lamp capacity, auto-switched giving effective 6000-8000 hours lamp life
  • Filter maintenance synchronized with lamp replacement
  • Lower operating power consumption than previous models
  • Wide range of inputs for a variety of source devices
  • D-Sub15 output for external monitor connection
  • Wide range of image adjustment
Product codes
Featuring a very wide range of lens-shift adjustment, and interchangeable lenses, this is a projector that installers can easily fit into awkward places, often reusing mounts and fixtures. The VPL-FX500L is so flexible that it can replace a very wide range of existing equipment.
Outstanding image quality is just one of the many benefits of Sony's 3 LCD-BrightEra technology. By reducing the effects of UV light, it lengthens panel life, brightens the image, and improves color rendition.
Maintenance is kept to an absolute minimum. Automatic lamp-switching means at the end of a lamp's working life, another one, already in place, is brought into use. Synchronized lamp and filter cycles halve the required number of maintenance visits. The VPL-FX500 is the perfect choice for venues that need an extremely bright projector with a high quality image and low maintenance costs
Sony VPL-FX500L - 3LCD projector - no lens
3LCD projector
Grey, white
Brightness
7000 lumens
Brightness (Colour)
7000 lumens
Contrast Ratio
2500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
No lens
Bulb type
High-pressure mercury 330 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Output
RGB
53 cm x 54.5 cm x 21.3 cm
20 kg
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-FX500L XGA LC...
