Sony VPL-SW631 UXGA 1600 x 1200 RGB HDMI 3LCD Projector
£1,199.11
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Bright, clear images with maximum 3,300 lumens color light output
  • Ultra short throw distance
  • WXGA resolution for detail-packed presentations
  • 3LCD BrightEra technology
  • Gamma adjustment
  • Up to 10,000 hours (in Low mode) long-lasting lamp for reduced maintenance and down time
  • Energy-saving features
  • Wired or wireless network presentation
  • Remote control from iOS mobile devices
  • USB Media viewer
  • USB display for easy one-cable PC connection
  • Input label function
  • Clear, rich audio from built-in speaker
  • Quick and easy to install
  • Easy wall mounting
  • Portability: Non-portable
  • Stock Status: In Stock
Product codes
Bright, high contrast widescreen projector for mid-size classrooms and meeting rooms: with easy installation and low ownership costs. The VPL-SW631 Ultra Short Throw projector is ideal for classroom or corporate use, with simple, flexible installation, low ownership costs and easy connection to other devices.
Present big, bright images over 2m across with the projector as little as 47cm from the screen or whiteboard, with less distracting glare and shadows.
Advanced 3LCD BrightEra panel technology by Sony ensures high contrast, widescreen WXGA images with excellent color stability. The projector's powerful 3,300 lumens color light output ensures that presentations are always seen clearly, even in brightly-lit environments.
Seamless integration with school or office networks can be enhanced with an optional Wi-Fi module, letting students wirelessly share homework, images and graphics from PCs, smartphones and tablets.
There's a wide range of smart energy-saving features built in. An extra-long lamp replacement time of up to 10,000 hours minimizes costs and reduces downtime in busy classrooms and offices.
Product Description Sony VPL-SW631 - 3LCD projector - ultra short-throw - LAN
Device Type 3LCD projector
Brightness 3300 lumens
Brightness (Colour) 3300 lumens
Contrast Ratio 3000:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Lens Ultra short-throw lens
Lens Shift Direction Horizontal, vertical
Bulb type Ultra high-pressure mercury 225 Watt
Bulb life cycle Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 320 Watt
Dimensions (WxDxH) 37.2 cm x 38.2 cm x 13.8 cm
Weight 6 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-SW631 UXGA 16...
£1,199.11
