Sony VPL-SW636C 1600 x 1200 RGB HDMI 3LCD Projector
Product codes
Bright, high contrast widescreen projector for mid-size classrooms and meeting rooms: with easy installation, a wide range of enhanced interactivity functions and low ownership costs.
The VPL-SW636C Ultra Short Throw projector is ideal for classroom or corporate use, with simple, flexible installation, low ownership costs, enhanced interactivity and easy connection to other devices.
Present big, bright images over 2m across with the projector as little as 47cm from the screen or whiteboard, with less distracting glare and shadows.
Advanced 3LCD BrightEra™ panel technology by Sony ensures high contrast, widescreen WXGA images with excellent colour stability. The projector’s powerful 3,300 lumens colour light output ensures that presentations are always seen clearly, even in brightly-lit environments.
Seamless integration with school or office networks can be enhanced with an optional Wi-Fi module, letting students wirelessly share homework, images and graphics from PCs, smartphones and tablets. Learning’s made richer and more collaborative with dual pen interactivity, allowing teacher and pupil to write on screen simultaneously. In PC-free interactive mode, you don't even need a connected PC to write, draw and annotate on-screen presentations.
There’s a wide range of smart energy-saving features built in. An extra-long lamp replacement time of up to 10,000 hours minimises costs and reduces downtime in busy classrooms and offices. A newly-designed wall mount bracket makes installation easier in rooms with low ceilings.
Product Description Sony VPL-SW636C - 3LCD projector - short-throw - LAN
Device Type 3LCD projector
Brightness (White) 3300 lumens
Brightness (Colour) 1900 lumens
Contrast Ratio 3000:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Lens Short-throw fixed lens
Bulb type Ultra high-pressure mercury 225 Watt
Bulb life cycle Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58), LAN
Video Modes 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i
Speakers Speaker(s) - integrated
Power AC 120/230 V (50/60 Hz)
Power Consumption Operational 341 Watt
Dimensions (WxDxH) 37.2 cm x 38.2 cm x 13.8 cm
Weight 6.3 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
