Sony VPL-SX226 Short Throw Projector S Series 2800LM XGA
£705.64
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Short throw distance
  • Advanced energy-saving features
  • Low TCO
  • Eco mode key
  • 3LCD BrightEra technology
  • Bright, clear images
  • Networked presentations
  • Control and management from any networked PC
  • Present wirelessly
  • Remote control for iPhone/iPad/Android phone
  • USB media viewer
  • USB display for easy one-cable PC connection
  • Customized input labels
  • Stylish blend-in design
Product codes
The wall-mountable short throw projector VPL-SX226 is suitable for using a projector with a white board. A short throw distance of 75 cm for an 80" screen is good for limited space in a classroom. The teacher can be free from the projector's glare and able to easily teach their students. By using this projector with an interactive white board the initial costs can be reduced.
This projector has a long-lasting lamp. The unique lamp dimming function by Sony reduces the lamp power usage and lamp power consumption. It's low TCO and usability means the user can enjoy bright images for a much longer time.
VPL-SX236 is a colorful and bright projector. Thanks to the 3LCD Sony "BrightEra ", the picture is colorful and the images are bright. And it also has vivid 2,800 lumen with XGA resolution. These specs are best for a classroom environment. It's easier for all of the students to see with this big screen size.
Smart connection with PC, Tablet and smartphone is also supported. The wireless presentation capability makes it simple to present files from your PC or smart phone/tablet.
Sony VPL-SX226 - 3LCD projector - short-throw - LAN
3LCD projector
Built-in Devices
Speaker
Brightness (White)
2800 lumens
Brightness (Colour)
2800 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
Short-throw fixed lens
Bulb type
Ultra high-pressure mercury 210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58), LAN
Video Modes
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
294 Watt
36.5 cm x 31 cm x 13.87 cm
4.4 kg
1 year warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sony VPL-SX226 Short T...
£705.64
