StarTech.com 0.3m (11in) Short Apple 30-pin Dock Connector to...
StarTech.com 0.3m (11in) Short Apple 30-pin Dock Connector to USB Cable with Stepped Connector
Product codes
Charge or Sync your iPhone, iPod, or iPad with reduced clutter. The USB2ADC30CM 0.3m Apple (30-pin) Dock Connector to USB cable for iPhone, iPod and iPad enables close-range syncing and charging of your iOS-enabled mobile digital devices, for situations where a longer cable would create clutter. Plus, the shorter cable design provides a portable solution that makes it perfect for carrying as a laptop accessory.
The USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 0.3m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 11in Short Apple 30-pin Dock to USB Cable for iPhone iPad - charging / data cable - 30 cm
Cable Charging / data cable
Technology Double shielded
American Wire Gauge (AWG) 28
Length 30 cm
Colour White
Connector USB - male
Connector (Second End) Apple Dock - male
Designed For Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.3m (11i...
