StarTech.com 0.3m (11in) Short White Apple 8-pin Lightning Co...
StarTech.com 0.3m (11in) Short White Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad
£10.44
Colours:
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Complements your white Apple mobile devices
  • No incorrect way of plugging the connector into your mobile device
  • Ideal for close-range device connections
  • Lightweight, portable cable, suitable for carrying as a laptop accessory
  • Length: 30cm
  • Stock Status: Clearance
Product codes
Charge and Sync your Apple Lightning-equipped devices with reduced clutter. The USBLT30CMW 30cm White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Perfect for close-range device connections, the shorter Lightning USB cables provide a portable solution that makes them perfect for carrying as a laptop accessory. Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 30cm Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 11in Short White Apple 8pin Lightning to USB Cable iPhone iPad - Lightning cable - Lightning / USB - 30 cm
Cable Lightning cable - Lightning / USB
Technology Double shielded
American Wire Gauge (AWG) 24/28
Length 30 cm
Colour White
Connector Lightning - male
Connector (Second End) USB - male
Features Sync and charge
Designed For Apple iPad mini; iPad with Retina display (4th generation); iPhone 5; iPod nano (7G); iPod touch (5G)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.3m (11i...
£10.44
