StarTech.com 0.3m (1ft) Coiled Black Apple 8-pin Lightning Co...
StarTech.com 0.3m (1ft) Coiled Black Apple 8-pin Lightning Connector to USB Cable iPhone iPodiPad
£12.76
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Charge your Apple Lightning-equipped devices with reduced clutter, in your car with this 1ft coiled cable. The USBCLT30CMB Black Coiled Lightning to USB Cable for iPhone, iPod, and iPad can comfortably be stretched out to up to 0.3m/1ft to reach your mobile device and when compressed can be tucked out of way, to provide simple, tidy connections - great for charging in your car (requires USB charge port).
Colored to suit your black mobile devices, this Lightning to USB cable provides a reliable solution for both syncing and charging and provides a compact solution that makes it perfect for carrying as an iPad or iPhone accessory.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
Product Description StarTech.com 1ft Coiled Lightning to USB Cable - Black - Apple 8 Pin Lightning Charger Cable for Your iPhone / iPad / iPod (USBCLT30CMB) - Lightning cable - Lightning / USB - 30 cm
Cable Lightning cable - Lightning / USB
Technology Shielded
American Wire Gauge (AWG) 24/28
Length 30 cm
Colour Black
Connector Lightning - male
Connector (Second End) USB - male
Features Coiled
Designed For Apple iPad mini; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.3m (1ft...
£12.76
