StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra H...
StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M
£4.50
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for close-range device connections, with no excess cable clutter
  • Lightweight, portable cable, suitable for carrying as a mobile accessory
  • Guaranteed reliability
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Create Ultra HD connections between your High Speed HDMI-equipped devices, with reduced clutter. The HDMM30CM 30cm High Speed HDMI cable enables close-range connections of your HDMI-enabled devices, for situations where a longer cable would create clutter.
Plus, this short HDMI cable provides a portable solution that makes it perfect for carrying as a mobile accessory. When used with an HDMI to Micro or Mini HDMI adapter such as our HDMI 2-in-1 T-adapter, you can connect mobile devices such as your Smartphone, or Tablet to an HD display, or your Digital Camera to a laptop.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high-definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
Product Description StarTech.com 0.3m 1ft Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI M/M - 30cm HDMI 1.4 Cable - Audio/Video Gold-Plated (HDMM30CM) - HDMI cable - 30 cm
Cable HDMI cable
Technology Double shielded
American Wire Gauge (AWG) 28
Length 30 cm
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.3m (1ft...
£4.50
