StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to...
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M
£7.39
32 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Cable and connectors are compliant with USB 3.0 SuperSpeed specifications
  • Supports high-speed data transfer rates of up to 480 Mbps
  • Aluminum-Mylar foil with braided shielding
  • Molded connectors with strain relief
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Connect a USB 3.0 Micro USB external hard drive to your computer. The USB3AUB50CMB SuperSpeed USB 3.0 Micro B cable provides a high quality connection to your Micro USB-equipped USB 3.0 devices.
The short 0.5m /1.5-foot cable length is perfect for close-range connections (e.g. connecting a portable hard drive to your laptop) and the lightweight, compact design fits nicely into any carrying case.
Product Description StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - USB 3.0 Micro B Cable - 1x USB 3 A (M), 1x USB 3 Micro B (M) 50cm (USB3AUB50CMB) - USB cable - 50 cm
Type USB cable
Technology Shielded
Features Molded, 5 Gbps data rate
Length 50 cm
Connector 10 pin Micro-USB Type B - male
Connector (Second End) 9 pin USB Type A - male
Compliant Standards USB 3.0
Colour Black
Designed For P/N: DKT30CVAGPD, S2510BPU337, S2510BU33PW, S251BMU313, S251BMU3FP, S251BPU313, S251BRU33, S251SMU33EP, S252BU313R, SLSODDU33B, SM2NGFFMBU33, SMS1BMU313, UNI251BMU33
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m (1.5...
£7.39
