StarTech.com 0.5m 1.6ft 10G SFP+ DAC Cable
£41.73
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Delivers reliable 10Gbps connections for 10GBase-T compliant networks
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
Product codes
Connect your MSA compliant 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com MSA Comp. SFP+ Direct-Attach Twinax Cable - 0.5 m (1.6 ft.) - 10GBase direct attach cable - 50 cm - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
50 cm
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m 1.6f...
£41.73
