StarTech.com 0.5m 1.6ft 10G SFP+ DAC Cable
£33.33
Select:
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco SFP-H10GB-CU1M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
  • Length: 50cm
  • Colour: Black
  • Stock Status: In Stock
Product codes
Connect your Cisco 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
Product Description StarTech.com Cisco SFP-H10GB-CU0-5M Compatible 0.5m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Passive Transceiver Module DAC Firepower ASR9000 - Lifetime Warranty (SFPH10GBC05M) - 10GBase direct attach cable - 50 cm - black
Type 10GBase direct attach cable - SFF-8431/SFF-8432
Technology Twinaxial
Features Passive cable
Length 50 cm
Connector SFP+ - latched
Connector (Second End) SFP+ - latched
Colour Black
OEM Manufacturer Equivalent Part Number Cisco SFP-H10GB-CU0-5M
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£33.33
