Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
Product Description | StarTech.com MSA Uncoded Compatible 0.5m 40G QSFP+ to QSFP+ Direct Attach Breakout Cable Twinax, 40 GbE QSFP+ Copper DAC 40 Gbps Low Power Passive Transceiver Module DAC, 40GE, 40GE Cable - Lifetime Warranty (QSFP40GPC05M) - 40GBase direct attach cable - 50 cm - black | Type | 40GBase direct attach cable - SFF-8436 | Technology | Twinaxial | Features | Passive cable | Length | 50 cm | Connector | QSFP+ - latched | Connector (Second End) | QSFP+ - latched | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Network Cable Type | 40GBase direct attach cable - SFF-8436 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 30 |
Impedance | 100 Ohm |
Length | 50 cm |
Weight | 36 g |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | FCC, RoHS, MSA |
Manufacturer Warranty | |
Service & Support | 2-year warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
