StarTech.com 0.5m CAT6 Cable - Black Slim CAT6 Patch Cable -S...
StarTech.com 0.5m CAT6 Cable - Black Slim CAT6 Patch Cable -Snagless RJ45
£3.52
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • For installation in high-density data centers
  • Designed for use with Gigabit networks
  • Length: 50cm
  • Colour: Black
  • Stock Status: In Stock
Product codes
This slim CAT6 cable meets all Category 6 patch cable specifications to deliver a reliable Gigabit network connection in high-density data center applications.
The design of this slim CAT6 patch cord is 36% thinner than standard networking cables, which allows better airflow and heat dissipation in tight spaces. The cable is also more flexible than standard Ethernet cables, so cable runs are easier in crowded network racks.
This cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break as you pull them through narrow spaces.
This CAT6 patch cable is tested to comply with ANSI/TIA 568 C.2 Category 6 requirements ensuring a reliable connection to your networking equipment. Certified with Low Smoke Zero Halogen (LSZH) fire rating, this patch cord ensures a safe connection.
The 50-micron gold connectors on the patch cable deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
Each CAT6 cable is manufactured using high-quality copper conductors and is carefully constructed and tested to keep Near-End Crosstalk (NEXT) well within acceptable limits. Plus, each cable is built with 28 AWG copper wire, to ensure peak performance for your demanding Ethernet applications.
Product Description StarTech.com 0.5 m CAT6 Cable - Slim CAT6 Patch Cord - Black - Snagless RJ45 Connectors - Gigabit Ethernet Cable - 28 AWG (N6PAT50CMBKS) - patch cable - 50 cm - black
Type Patch cable - CAT 6
Features Snagless, Slim, minimised Near-End Crosstalk (NEXT)
Length 50 cm
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m CAT6...
£3.52
