StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cabl...
StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cable - HD15 M/M
£6.26
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com Lifetime warranty
  • Ferrite cores to help eliminate EMI interference
  • Supports high resolution VGA video (1920x1200 or above), suitable for a wide range of applications
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Connect your VGA monitor with the highest quality connection available. The MXTMMHQ50CM 0.5m High Resolution VGA Cable (50cm) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 50 cm
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded, thumbscrews, strain relief, ferrite core
Length 50 cm
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards UL 2919, RoHS, NEC-CMG
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m Coax...
£6.26
