StarTech.com 0.5m Dock Connector to USB Cable ASUS Transforme...
StarTech.com 0.5m Dock Connector to USB Cable ASUS Transformer Pad and Eee Pad Transformer / Slider
£8.74
Select:
Delivery:
Standard: 1-3 working days
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Charge your ASUS Transformer/Slider Tablet with reduced cable clutter. The USB2ASDC50CM ASUS Transformer USB Cable enables close-range connections to your PC or Mac computer or to your laptop, for transferring data and charging your ASUS Eee Pad Transformer (TF101, Prime, etc.), ASUS Transformer Pad (Infinity, etc.) or ASUS Eee Pad Slider.
The short 1.5ft/0.5m cable minimizes the clutter of excess cable and provides a portable solution that makes it perfect for carrying as a tablet accessory.
For convenience, this versatile ASUS tablet cable can be connected to a computer USB port for data transfers while you are working. Or you can connect the cable to the USB power adapter which was supplied with your ASUS Pad, for simple charging from an available (wall) power outlet.
This ASUS Transformer USB Cable is designed and constructed for maximum durability, making it a dependable replacement for damaged or misplaced data / charging cables.
Product Description StarTech.com 50cm Dock Connector to USB Cable ASUS Transformer Pad Eee Pad - charging / data cable - 50 cm
Cable Charging / data cable
Technology Double shielded
American Wire Gauge (AWG) 24/30
Length 50 cm
Colour Black
Connector ASUS 40-pin Dock Connector - male
Connector (Second End) USB - male
Designed For ASUS Eee Pad Slider; Eee Pad Transformer; Transformer Pad
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m Dock...
£8.74
