StarTech.com 0.5m HDMI to DVI-D Cable - M/M
£7.44
31 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Lightweight, portable cable, suitable for carrying as a laptop accessory
  • Ideal for close-range device connections
  • Ensures compatibility between two distinct digital video interfaces, and eliminates the need for multiple cables and clutter
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Connect your DVI-D or HDMI-enabled display with reduced clutter. The HDDVIMM50CM 0.5m HDMI to DVI-D cable allows you to connect an HDMI-enabled device to a DVI-D display, or a DVI-D device to an HDMI-capable display at shorter distances and with reduced clutter.
Ideal for close-range device connections, this short HDMI to DVI cable provides a portable solution that makes it perfect for carrying as an accessory for your laptop.
Product Description StarTech.com 0.5m HDMI to DVID Cable M/M - video cable - HDMI / DVI - 50 cm
Cable Video cable - HDMI / DVI
Technology Double shielded
American Wire Gauge (AWG) 28
Length 50 cm
Colour Black
Connector DVI-D - male
Connector (Second End) HDMI - male
Features Moulded, strain relief
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m HDMI...
£7.44
