StarTech.com 0.5m High Speed HDMI Cable - Ultra HD 4k x 2k HD...
StarTech.com 0.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M
£6.18
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Gold-plated connectors help prevent corrosion, to ensure a high quality HDMI connection
  • Molded HDMI connectors with strain relief maintain a durable connection, helping to prevent damage to the connectors, for long term, error-free HDMI to HDMI audio-video performance
  • Short HDMI cable design is ideal for close-range device connections and provides a portable solution that is suitable for carrying as a laptop or netbook accessory
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Create Ultra HD connections between your High Speed HDMI-equipped devices. The HDMM50CM High Speed HDMI cable (0.5m/1.6ft) features 2 gold-plated HDMI (male) connectors and durable high quality construction to provide a dependable HDMI to HDMI connection between devices such as Blu-Ray Disc players, HDTVs, DVD Players, stereo receivers, projectors and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
Product Description StarTech.com 0.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - 50cm HDMI 1.4 Cable - Audio/Video Gold-Plated (HDMM50CM) - HDMI cable - 50 cm
Cable HDMI cable
Technology Shielded
American Wire Gauge (AWG) 28
Length 50 cm
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Features Moulded
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m High...
£6.18
