StarTech.com 0.5m Micro USB Cable A to Down Angle Micro B
Product codes
Charge or sync your portable Micro USB devices at short distances, with the cable kept out of the way. The USBAUB50CMD 0.5m USB to Down Angle Micro USB Cable provides a high quality connection between your Micro USB 2.0 mobile devices (smartphones, digital cameras, Tablet PC devices, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The down-angled Micro USB connector allows you to access your mobile Micro USB devices, while keeping the cable out of the way, and stress away from the port.
Perfect for close-range device connections, StarTech.com shorter micro USB cables provide a portable solution that makes them perfect for carrying as an accessory for your tablet or laptop.
As an alternative, StarTech.com also offers a 0.5m USB to Up Angle Micro USB Cable (USBAUB50CMU), which provides the same convenience as this down-angled cable, but allows you to connect to your Micro USB device from the opposite direction.
StarTech.com 0.5m Micro USB Cable - A to Down Angle Micro B - USB cable - 50 cm
USB cable
Double shielded
90° connector, molded, strain relief
Length
50 cm
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m Micr...
