StarTech.com 0.5m Mini USB Cable - A to Down Angle Mini B
Key features
  • Lightweight, portable cable, suitable for carrying as a laptop or tablet accessory
  • Reduce stress on your mobile device connector
  • Unrestricted access to your Mini USB mobile device
Product codes
Connect your portable Mini USB devices at short distances, with the cable kept out of the way. The USBAMB50CMD 0.5m USB to Down Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The down-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
Perfect for close-range device connections, StarTech.com shorter mini USB cables provide a portable solution that makes them perfect for carrying as an accessory for your tablet or laptop.
As an alternative, StarTech.com also offers a 0.5m USB to Up Angle Mini USB Cable (USBAUB50CMU), which provides the same convenience as this down-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
StarTech.com 0.5m Mini USB Cable - A to Down Angle Mini B - USB cable - 50 cm
USB cable
Double shielded
90° connector, molded, strain relief
Length
50 cm
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m Mini...
