StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Ca...
StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets
£4.30
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Keep your Micro USB-equipped mobile digital device in its protective case while charging
  • Compact design fits nicely into any carrying case
  • Ideal for close-range device connections, with no excess cable clutter
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Charge and Sync your Micro USB-equipped Smartphone or Tablet with reduced clutter. The USBAUB50CMBK Micro USB Cable is perfect for close-range connections, and provides a reliable solution for charging and syncing your Micro USB mobile devices. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
The short 0.5m cable length makes this an ideal charge cable for in-car use or to reduce clutter when syncing to your laptop - perfect for people on the move, for providing simple, tidy connections.
Replace the cable that came with your device and keep one as a spare in your laptop bag, backpack or other carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
Product Description StarTech.com 0.5m Mobile Charge Sync USB to Slim Micro USB Cable M/M - USB cable - 50 cm
Type USB cable
Technology Double shielded
Length 50 cm
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m Mobi...
£4.30
