StarTech.com 0.5m Orange Cat5e Patch Cable
£3.06
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector clip protectors
  • Carefully constructed and tested, to keep Near End Crosstalk (NEXT) well within acceptable limits
  • Colored hoods for departmental color coding
  • Molded strain relief prevents the cable from being bent at sharp angles at the RJ45 connector, to minimize the stress at the plug termination point
  • Constructed with top quality components
  • High quality 24 AWG copper wire
Product codes
The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
  • Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
  • Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
  • Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
StarTech.com 0.5m Orange Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - orange
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Snagless, stranded, PoE ready
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m Oran...
£3.06
