StarTech.com N6PATC50CMOR. Cable length: 0.5 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 26 g. Package width: 200 mm, Package depth: 220 mm, Package height: 10 mm
Product Description | StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Orange, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMOR) - network cable - 50 cm - orange | Type | Network cable - CAT 6 | Technology | Unshielded twisted pair (UTP) | Wiring Scheme | T568B | Wires per Cable | 8 wires | Features | Molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), PoE ready | Length | 50 cm | Connector | RJ-45 - male | Connector (Second End) | RJ-45 - male | Colour | Orange | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Network cable - CAT 6 |
Jacket Material | PVC |
American Wire Gauge (AWG) | 24 |
Pairs per Cable | 4 pairs |
Plated Connector | Gold |
Length | 50 cm |
Weight | 387 g |
Colour | Orange |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS, ETL, TIA/EIA-568-B - up to 500 MHz |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
