StarTech.com 0.5m Red Cat5e Patch Cable
£3.80
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector-clip protectors eliminate cable snags and breaks during installation
  • Red PVC jacket for color coding your connections
  • 50 cm in length for shorter connections, without the clutter of excess cable
  • Moulded RJ45 connectors prevent cable damage and also provide strain relief
  • 50-micron gold-plated connectors for a clear signal
  • High-quality 24 AWG copper wire
  • Length: 50cm
  • Colour: Red
Product codes
The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
  • Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
  • Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
  • Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
Product Description StarTech.com 0.5m Red Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - red
Type Patch cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Features Snagless, stranded, PoE ready
Length 50 cm
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£3.80
