StarTech.com 0.5m USB 2.0 A to B Cable - M/M
£3.54
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Connect USB 2.0 peripherals to your computer
The USB2HAB50CM 0.5-meter USB A-to-B cable features one USB ''A'' male connector and one USB ''B'' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives. Constructed of only top quality materials and expertly designed for durability, this USB 2.0 A-B cable is backed by StarTech.com''s Lifetime Warranty.
The StarTech.com Advantage
  • Short cable length provides maximum portability, making this an easy solution to store in a laptop bag or carrying case
  • Durable design, with high quality USB connectors
  • Backed by StarTech.com lifetime warranty
Product Description StarTech.com 0.5m USB 2.0 A to B Cable M/M - USB cable - 50 cm
Type USB cable
Length 50 cm
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m USB...
£3.54
