StarTech.com 0.5m USB 2.0 C Micro-B Cable
£12.60
11 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Charge and sync your USB 2.0 Micro-B devices from a USB-C host, with reduced clutter. This USB-C to Micro-B cable lets you charge and sync your USB 2.0 Micro-USB mobile device from a USB Type-C laptop, USB-C wall charger, car charger or power bank.
The cable also lets you connect an external Micro-USB drive for easy data backups.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your Micro-USB mobile devices with your laptop.
You can also use the cable to charge your devices from a USB-C wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
The cable can also be used to back up data from your USB-C or Thunderbolt 3 computer to an external Micro-USB 2.0 drive. The short cable lets you set up in small offsite workspaces, or in a coffee shop or hotel room, so that you can install your equipment without excess cable getting in your way.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
Product Description StarTech.com USB-C to Micro-B Cable - M/M - 0.5 m - USB 2.0 - USB-C cable - 50 cm
Type USB-C cable
Technology Shielded
Features Sync and charge
Length 50 cm
Connector 24 pin USB-C - male
Connector (Second End) 5 pin Micro-USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m USB...
£12.60
