StarTech.com 0.5m USB 2.0 C to A Cable M/M
£6.81
31 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Offers 0.5 meters in cable length for close-range connections
  • Convenient, reversible USB-C connector makes every connection easy
  • Guaranteed reliability with our lifetime warranty
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Connect your USB Type-C devices to your computer, with reduced clutter. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall charger, car charger or power bank.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices from your laptop.
You can also use the cable to charge your USB-C devices from a USB-A wall charger, car charger or power bank. It's the ideal cable for commuters, for in-car use or to reduce clutter when syncing with your laptop.
Replace the USB-C charging cable that came with your device or keep one as a spare in your laptop bag, backpack or other carrying case.
Product Description StarTech.com 0.5m USB C to USB A Cable - M/M - USB 2.0 - USB cable - 50 cm
Type USB cable
Technology Double shielded
Features Sync and charge
Length 50 cm
Connector 4 pin USB Type A - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB / USB 2.0
Colour Black
Designed For P/N: DKT30CVAGPD
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m USB...
£6.81
