StarTech.com 0.5m USB 2.0 USB C Cable
£5.53
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Offers 0.5 meters in cable length for close-range connections
  • Convenient, reversible USB-C connector makes every connection easy
  • Guaranteed reliability with our lifetime warranty
Product codes
Charge your USB 2.0 USB-C devices, with reduced clutter. This USB-C to USB-C cable makes it easy to charge and sync your USB 2.0, USB Type-C mobile devices using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices with your laptop.
You can also use the cable to charge your USB-C devices from a USB-C wall charger, car charger or power bank. It's the ideal cable for commuters for in-car use or to reduce clutter when syncing with your laptop.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
StarTech.com 0.5m USB C Cable - M/M - USB 2.0 Type C Cable - USB-C cable - 50 cm
USB-C cable
Shielded
Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 0.5m USB...
£5.53
