StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube...
StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink
£4.51
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Our thermal CPU paste improves the effectiveness of CPU coolers by thermally bonding the CPU to the heatsink.
A high quality metallic solution that helps to ensure maximum dissipation of heat generated by the CPU for optimized performance and greater system stability; and is more effective than standard silicon-based heat grease/CPU paste, providing optimum protection against CPU heat damage.
The StarTech.com Advantage
  • Better thermal conductivity over standard silicon-based compounds and negligible electrical conductivity for effective and safe use in high performance applications
Product Description StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube processor heatsink paste
Product Type Processor heatsink paste
Weight 1.5 g
Manufacturer Warranty 1-year warranty
Designed For P/N: FANP1003LD, FAN370PRO, FANDURONTB, FANP2SECC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1.5g Meta...
£4.51
