StarTech.com 1.5m HDMI to DVI-D Cable - M/M
£10.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Organize your HDMI and DVI-D devices as needed, with less clutter and at a distance that suits your specific requirements, with a unique 1.5 meter cable length
  • Enables a high-quality, corrosion-free connection through gold-plated contacts
  • Length: 1.5m
  • Stock Status: In Stock
Product codes
The HDDVIMM150CM HDMI to DVI-D cable comes in a non-standard 1.5 meter/5 foot cable length allowing for a convenient connection distance and enabling you to position your DVI-D or HDMI-enabled devices as needed.
This bi-directional cable enables you to connect a DVI-D video card to a display that incorporates HDMI technology, or enables you to connect an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high-performance cable is designed to provide the best quality picture available through HDMI technology or DVI digital connections.
Product Description StarTech.com 1.5m HDMI to DVID Cable M/M - video cable - HDMI / DVI - 1.5 m
Cable Video cable - HDMI / DVI
Technology Shielded
American Wire Gauge (AWG) 28
Length 1.5 m
Colour Black
Connector DVI-D - male
Connector (Second End) HDMI - male
Features Moulded, strain relief
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1.5m HDMI...
£10.26
