StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HD...
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M
£7.22
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Enables a high quality, corrosion free connection through gold-plated contacts
  • Guaranteed reliability
  • Organize your HDMI devices as needed, with less clutter and at a distance that suits your specific requirements, with a unique 5 foot cable length
Product codes
Create Ultra HD connections between your High Speed HDMI-equipped devices over a unique 5 foot connection distance. The HDMM150CM 1.5m High Speed HDMI cable comes in a non-standard 5 foot cable length allowing for a convenient connection distance and enabling you to position your HDMI-enabled devices as needed.
The cable features two gold-plated HDMI male connectors to provide a dependable HDMI to HDMI connection, while the unique cable length makes it perfect for watching videos from your laptop on your HDMI TV or for boardroom presentations when connecting your laptop to an HDMI-enabled projector.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com 1.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable M/M - HDMI cable - 1.5 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
28
Length
1.5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
P/N: DP2VGA3, VGA2HDU
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1.5m High...
£7.22
