Use this cable to connect your USB Type-C computer directly to a Mini DisplayPort monitor, without additional adapters. This USB-C to Mini DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your Mini DP monitor. The adapter offers a connection distance of up to 1.8 m (6 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1.8 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For shorter installations, StarTech.com also offers a 1 m (3 ft.) USB-C to Mini DisplayPort cable (CDP2MDPMM1MB), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
Product Description | StarTech.com 6ft / 2m USB-C to Mini DisplayPort Cable - 4K 60Hz - Black - USB 3.1 Type C to mDP Adapter (CDP2MDPMM6B) - DisplayPort cable - USB-C to Mini DisplayPort - 1.8 m | Type | DisplayPort cable | Features | 4K60Hz (3840 x 2160) support, DisplayPort Alternate Mode support, 5.1 audio channel support | Length | 1.8 m | Connector | 24 pin USB-C - male (input) | Connector (Second End) | Mini DisplayPort - male (output) | Compliant Standards | USB 3.1 / Thunderbolt 3 / DisplayPort 1.2 | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Length | 1.8 m |
Colour | Black |
Weight | 58 g |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB 3.1 / Thunderbolt 3 / DisplayPort 1.2, FCC, RoHS |
Dimensions & Weight (Shipping) | |
Shipping Width | 1.2 cm |
Shipping Depth | 22 cm |
Shipping Height | 0.8 cm |
Service & Support | 3-year warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
