StarTech.com 1 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45...
StarTech.com 1 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
£7.24
21 in stock
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high level of performance is an excellent choice for Power over Ethernet (PoE) applications. All of the Cat 6a cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that the Cat6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
Product Description StarTech.com 1 ft Blue Cat6a / Cat 6a Shielded Patch Cable 1ft - patch cable - 30 cm - blue
Type Patch cable - CAT 6a
Technology Shielded twisted pair (STP)
Wiring Scheme T568B
Shielding Material Aluminium-polyester foil
Wires per Cable 8 wires
Features Molded
Length 30 cm
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1 ft Cat...
£7.24
